NMNA: HRE wheels
Wouldn't 5x120.65 be a problem?
Not a significant problem. They are easy enough to mount. The center bore will likely either be 70.3mm (too small) or 73.9mm (too big). So you either need to find/fabricate hub centric rings or machine the center. I honestly don’t know what runs 73.9. 120.65 are usually GM wheels, often Corvette.
Edit, they are 73.9’s. I don’t know what that is from. I’m sure @floridabmx does...
