I did see some leaking. Should I have not used this? Was recommended by a E9 friend of mine
I guess the question now would be, did you replace the oil pan gasket if that is where it is leaking, if not, where do you see the leak (s). I can't say what you did is bad or good, that is above my paygrade here. Others will chime in I'm sure.I did notice leaking. I have only driven 50 or so miles This was recommended to me by a e9 friend. Yes I put in 6 quarts
Did you notice any leak after driving it say...10K miles? Just curious. Or any other issues? Or did you literally just change to full synthetic? Not many miles since? And shouldn't it take 6 quarts if replacing the filter at the same time?
Change friends not oil.I did see some leaking. Should I have not used this? Was recommended by a E9 friend of mine
Maybe just a drop is the key we have all been missing. At least it will smell nice! そうそう
