Orange trouble light in the gauge pod
bossrobot
Berkeley ca.
What does the orange O light being on indicate ? For reference I mean the one in the Temp/Fuel pod, top left of the Oil pressure light. Mine is on/ staying on, and I am having difficulty figuring out what its for? I think it used to come on and then turn off after a bit.
O is the oil pressure light, check the wire at the sender unit or replace the sender unit
That’s what the oil pressure light does. It stays on for a few seconds until pressure goes above a certain level, probably around 10 psi depending on the sender you have.
If yours stays on, I would make sure you have enough oil and oil pressure before running that motor.
Ya, check that oil level.
Check your sending unit. Maybe bad or always grounding.
If all good, check your oil pressure with a mechanical gauge
My wire to the sending unit on the head used to come loose but stays close in contact and hence the light came on and off.
