Hello, Tom from germany speaking/Asking basically 2 Questions:
1) Has there anyone replaced the original carburetors on a 3.0 CS (1972) by some different carbs but with untouched Engineblock/head/crankshaft/pistons...?
Is there a substitution carboretor kit existing which works after installing / adjustment without modifying anything else?
(i´m not seeking for more power - if there will be 5,10 PS more - fine, if same as old fine too)
Head# 1250019 (9) Block: (i think its xx 446)
2) When having a different engine (Head/ Engineblock of the 3.0SI injection e3 e9) which caburetor set would work here without touching Engineblock/head/crankshaft/pistons? (only removing the injection itake manifold and replace by Carbs) maybe just mod the fuel pump external instead the mechanical attahced to 019 head
the head number is 1277358 + Block 753L A 12 01
Does anybody have done this "modification" / exchange and what are the exact Products (+ numbers) used?
(What did maybe not work -> experiences highly appreciated)
Thank you, Tom
Thank you, Tom
