For use with the original metal expansion tank, I have conflicting information on which cap is correct - with or without an outer seal?
One source states the following:
Older metal cooling system caps manufactured by German OEM suppliers like Blau and Reutter for vintage BMWs (such as the E3, E9, E10/2002, and early E21/E30 models) feature a distinct internal metal and rubber configuration:
• Upper Plate: The upper sealing surface relies on a solid brass, copper, or stainless steel metal disc that seats directly against the upper lip of the radiator neck. It does not utilize an attached upper rubber gasket. Instead, it acts as a mechanical metal-to-metal atmospheric seal to guide overflow fluid safely down the overflow tube.
• Lower Seal: The critical pressure-holding element is located at the bottom of the spring-loaded plunger. This contains a thick lower rubber seal that presses firmly into the lower seat of the radiator neck to maintain the required 1.0 bar (approximately 14.5 to 15 PSI) cooling system pressure.
Another source states that you need both the inner and outer seal.
Thoughts?
Thoughts?
