Parcel Shelf Resto
bavbob
Boston, Ma
My 73 Euro CS shelf was trashed, looks like plywood and black vinyl. Was there any padding between the wood and vinyl? Also, multiple small holes in the wood so I assume it was held in place with the usual plastic clips? clip-panel-bmw-e36-e46-e34-e39-e38-x5-z3-z8-por-_iZ60366847X.jpg
There is a padding in between the vinyl and the wood. I used a wool felt material. My parcel shelf was held in place by a series of screws around the perimeter of the massive speaker holes previously cut out. I did not use clips when installing my new shelf, but my seat belts/harnesses are bolted through the shelf and I also have two screws through the shelf holding my center brake light.
if you have speaker cutouts, the wool felt will also be a better sound insulator than thin foam.
