Parts Needed: Brake Cable and Rubber for Horn
scottevest
Ketchum, Idaho
Do you know any place that has these parts readily available? Rogerstii says 2+ weeks to get the brake cable and no idea on the rear bumper rubber buffer.
Thanks.
BMW​
BMW E9 3.0cs Rear Bumper Rubber Buffer​
$0.00
SKU:
51121810973 L
BMW​
BMW E9 3.0cs Parking Brake Cable​
$72.21
SKU:
34411118578
try getbmwparts.com
you might want to try walloth + nesch as the bumper horn piece is MUCH cheaper
Wow. That rubber is crazy expensive; not sure worth it.
Scott - the rubbers are expensive because they often rusted. Water sometimes can get trapped inside the underrider when the small drain holes at the bottom get clogged up. Then the bolts molded into the rubbers can rust. I've actually installed several small washers between my underriders and the body to ensure water cannot get trapped in there.
p.s. Don's price is outstanding for those parts.
Hi Don
Do you have the rear under rider rubber as well?
Thanks Tim
There is also offer on eBay for consideration:
or directly (even cheaper)
