Pistons, Try
Mahle
KS
Alcan
Expect to pay at least £100 - £200 each.
Some things to think about.....
As far as I am aware all the "3 litre" engines, used the same diameter piston, basically 88.97mm and if my fading memory is correct these are the same diameter as those used in the M10 engine in the 2002 range. Stroke was the deciding factor as far as I am aware.....
"3 litre" Capacities
2966cc = 3.0 (E3/E9)
3188cc = 3.3 (E3/Bavaria)
3277cc =3.3 (E3/Bavaria)
Stoke
3.3 (3188cc) = 86.0mm
3.3 (3277cc)=88.4mm
1).. If you know the exact dimensions, including the ring thicknesses, groove numbers etc you might be able to cross reference with another manufacturer
I know somebody who found the correct pistons for a rare 6 cylinder MG were just about the same as those used in early ford V8's, all he had to do was machine the crown down a bit
2).. If you have the original pistons, you can get new rings, they come in "standard" sizes. If too big the ends can be carefully filed down
3)..If the bores are worn but pistons servicable, believe it or not it might actually be cheaper to get the block resleeved and bored back to original size, I did this with one engine a few years ago.
4).. Do you know any really good engine machine shops/ race/rally engine prep places? - Got talk to them!
5).. If really deperate mortgage your house and sell your body to science and talk to BMW :shock:
As to "Light" wings, rocking horse pooh is more common! 2nd hand or NOS is your best bet...
Malc
