Mike Goble
My guess is that you have a heat soak problem on the suction side of the pump, a vapor lock of sorts. When the system is cool it works fine, and as long as you have cooling fuel running through the suction line, things work properly. When you stop the engine and let things sit for a while, heat builds up in the system and you develop a situation that causes you to lose suction on your fuel pump. It cold be an actual vapor lock or possibly a vacuum leak that only happens when the system is warm. Your car runs far enough to empty the bowls in the carbs and then it quits. You then have to sit long enough to allow the system to cool enough to alleviate the problem.
