pictures of reassembling the sub axles into the rear A arm?
charofire
Can someone share any pictures of reassembling the e9 sub axles into the rear A-arm? I understand a press is needed, but some pics would be really helpful.
eriknetherlands
Netherlands, Eindhoven area
uhm, not 100% familiar with US terminology I see: What is a 'rear A-arm"?
If it's somewhere in the rear suspension, I think I have plenty of pics for you. I did my full rear axle rebuild with just a big vice, nuts, botls washer and some steel tube sections.
If you talk about the 4 rubber bushings in the (what I think is called trailing arm), then I used this method: a threaded rod , a piece of tube to prevent it expanding, and a few adequately sized washers, some lube and a nut to pull the rubber in. (see pic)
charofire
Hi Erik - yes please - looking for pictures for the full axle rebuild that you did with a vice, etc, and any tips you have on getting those 4 rubber bushings in.
Ajay
Irvine, CA
Here is what I used when I reassembled mine. Copy amd pasted this diagram on a ms word document and made it bigger. Harbor Freight sells a Bearing press that worked fine for my reassembly as well.
eriknetherlands
Hi, I had a look but I do not have other pictures that detail how to install the 2*2 rubbers back into the rear trailing arm / A-arm in the rear axle assembly. I member that I basically pulled them in using a long M10 threaded rod + the metal tube as a sleeve as in the previously supplied picture. The sleeve prevents the rubber from expanding, thus the only way it can go is fowards.
Then with a simple socket driver you turn the bolt and nut and you pull it in; I probably used some light oil. No powertools, here, it just required hand force (the man kind, not the child kind).
I know this because I still can see the 'bite-marks' of the steel tube into the powder coated surface of the rear trailing arm.
