POWER BOOSTER
Candia4441
California
Hello, I need a 2002tii power booster I have 3 weber on my new engine and original booster is on the way 2002tii booster is very small and works on E9
please let me know if you have one I like to buy.
Candida - put WTB and exactly what you want in the title. Like "WTB - 2002tii brake booster"
Don't make people guess whether you are buying or selling a booster and what type of booster it is... Be specific. It'll work better
Hello,
I did say what exactly I want please tell me what WTB stands for and I am not a mechanic I am construction guy and I explain the best of my knowledge and I have 2 E9 there is 3.0cs and I have 2800cs when I replace a part on one and it works good I am upgrading the other one to if people will think I am buying and selling parts I don't know what to say however thank you for your attention and help me to fined a part that I need.
Hello,
WANTED to BUY (WTB)
If you have not already bought the carb kit, I suggest you consider buying a kit that is specifically engineered to fit our cars rather than a generic kit with a BMW M30 manifold.
For example, call Korman Autoworks and see if their kit fits your car without modification to the braking system. You also have the advantage of working with a seller who has over 40 years of experience putting triple Weber’s on BMW M30’s.
(Scroll about 1/2 way down to read about their triple Weber kits
Also, give these guys a call to see if their system is compatible with your stock brake booster:
Korman's intake manifold does fit without changing to the tii booster; I have Korman manifiold in my car. Not sure if the IE solution will fit. However, even if they can be made to fit without modifying the braking system, your choices for air cleaners are very limited with the stock booster in the car. I changed to the tii booster when I did my triple Weber install. More discussion on brake boosters here: https://e9coupe.com/forum/threads/tii-brake-booster-to-clear-dcoe-webers.36474/#post-308580
Also fyi, there were two tii boosters sold here within the past month or six weeks. In both cases, the seller used the manufacturer name and part number to advertise the part. If you are looking for a tii booster, you should also be watching for sales of a "Bremsgerat T51."
The triple Weber setup will not clear the stock tstat housing with the Korman intake mainfold, and I'm pretty sure from looking at the IE setup that it will have the same problem. Korman makes a tstat housing that is modified to address this problem. Alternatively, Markos came up with a spacer that also helps with tstat housing clearance issues and was rather elegant as I recall, but that was after I did my install. Contact Markos if you want to explore that.
