As I noted in my prior thread on "Electrolysis" (No Stan, we are not discussing the cosmetic removal of unwanted hair!) -http://www.e9coupe.com/forum/showthread.php?t=18182 - I am in the process of replacing my hoses, tstat and water pump.
In that thread, I posted a picture of the water separator/tstat housing in part because of the corrosion on the tubes, and in part because of the somewhat rusty color inside. Moving right along, yesterday I pulled the engine block drain plug and to my surprise, nothing at all exited the engine block. In addition, the plug is not even moist; instead the plug looks dark and dry and black, sort of like a spark plug with carbon fouling:
From this picture, there was clearly coolant remaining in the system:
Here is a picture of some grunge on the front of the water pump, which I removed spilling coolant all over the engine bay and the floor:
And here is a picture of the block where the water pump was pulled. That brownish color in the coolant passages (which is somewhat washed out by my drop light) looks like rust to me. Note there is still coolant in there, even though the block drain plug is out.
I was planning on merely putting a hose in the head and running water through it for a while, but that plan involved drainage out of the drain plug.
With the brownish color inside the water separator/tsat housing and on the front of the block, the grunge on the water pump impeller, and the fact that nothing drains when I pull the engine block drain plug, I am concerned about whether I may have a blockage within the engine coolant passages somewhere.
Thoughts on how I should attack this?
