Specifically under the section of the seat belt warning lamp, is there a layer of metal or is it only wood & vinyl?
Dremel?Feels like metal, I want to enlarge the hole that the FSB light wires go through, but not even sure a right angle drill would fit between it and the glass. Metal makes it more challenging. My AFR to FSB light housing project is proving to be more challenging than my 5 speed conversion.
Dremel?
You’ve removed the base that holds the light? It sits in a large rectangular opening. Any access behind the speaker?Yeah that's what I'm thinking, off to see if they make a right angle drill. It's surprisingly tight back there, even need a flex screwdriver to get the FSB base screws out.
