Rear and front Sway bar torque numbers help
Goose
Dallas, Texas
I just got new bushings made out of urethane to replace the old worn out rubber bushings.
Since the new ones are much stronger, does anybody knows the torque numbers I need to apply?
Thanks in advance.
I just tightened them until they were very tight by feel, that's all I did. Urethane does not compress much at all.
Urethane can be pretty hard so be prepared to possibly hear some squeaking.
My Suspension Techniques for Athena & Ireland Engineering for Vern sway bars came with a small tube of urethane safe grease to use on the frame mount bushings to reduce noise. So far, I haven't heard any squeaks.
Also place the bolts upside down. Somehow between road debris etc, they get bent if sticking down.
