Hi guys
I just rebuilt my rear brake pressure regulator valve.
I used a pmb kit that is meant for an early Porsche.
Anyway I took mine off and cleaned it and glass bead blasted it before I took it apart.
It was easier to keep the blast media out that way .
It is spring loaded so I put it in a hydraulic press so that I could hold it while I removed the 4 m6 screws holding it together.
Once I had the screws out , I slowly released the hydraulic press to let the spring pressure off.
It separated by about 20 mm then the spring was free.
I took all of the internals out and cleaned them.
There is a type of sliding piston which has 2 seals on it , 1 o-ring and 1 radial seal.
They need replacing, the o-ring is easy.
The radial seal is difficult to do.
The kit comes with a tapered tool which you put onto the end of your piston , then you have to push the new seal up the taper and onto the shaft until it pops into its groove.
I used hot water to make the seal softer and I used lubricant to help also.
It was not easy !!!
Note the tapered tool in the Porsche kit was too short for the Bmw part which left a reduced diameter with a step ahead of it on the shaft , a kind of “ trough “so I made up the difference by wrapping masking tape around and around the shaft until it was the same diameter as the tool and the shaft , I didn’t want the seal to fall into the “ trough “.
Once that was done I was able to slide the seal up the the taper , over the masking tape and on into its groove on the shaft.
Then when all of the seals and o-rings are replaced, and greased up , you use the 4 new screws to put it back together. The screws are longer than the originals so they are long enough to pull the spring down so you don’t need to use a press.
I hope that might be of some help, if others are planning on rebuilding theirs.
It was not easy !!!
