Rear interior panel removal question
Stan
Newmarket, New Hampshire
I know this must be fairly easy because I did it in 2002. I just can't remember if I need to remove a few bits before prying off the panel. So far the rear seats and armrests are out and I just need to get the panel off to access the waist-band trim on the exterior.
Help!
rear interior panel
Clips, just like the front, then down from the trim/wood piece, and out.
do you have to remove the rear arm rests and seat to get out the rear panel? If so, how does one remove the rear seat and armrests?
Lift up seats and remove, you need to pick up the front and let the back drop an inch to release from bracket. Side armrests are held with two screws, one on bottom bulkhead, one near C pillar. Pull bottom of panel outwards then down.
When removing the arm rest as Chris outlined, have to remove the arm rest window switches and mark where the wires go.
Stan,
If you need to get the whole window mechanism out, go slowly and mark everything so your adjustments don’t change, clean all mounts first then use a permanent marker and take photos on your phone, that way you’re in with a chance of getting it all back together and working again.
Cheers John
