Rear subframe question
de coupe
arizona
Just a question or two I was at the local parts place the other day some one made the suggestion of putting a e28 rear subframe in the coupe
Why would that be better than the e9
Is it stronger
Better options as far as brakes
Better options as far rear diffs
Better camber/toe
Any insight would be helpful
Is it stronger
Better camber/toe
Although an E28 rear subframe looks similar you need to remember that
1.. Diff rear mount is different, would need to modify
2.. Springs are combined with shocks, would need to modify suspension mountings in rear arches.
3.. I think the trailing arms are longer, wheels may not be centered in arches.
4.. Diff housings are different, might need to modify/shorten prop shaft.
I considered it but decided it was too much work
The most common answer is for the diff options. Side loaders aren't exactly common, especially side loader LSDs.
True but they are available, at a price
They were use on E3, E12 and very early 6 series, the E number I don't know :?
