Rear View Mirror
Ed G
Eastern Connecticut
Rear view mirror from a Northeast car- Cool and Shady. Not in bad shape. Button works fine. See pics below. $70.00 sends it to you. Please PM- Thanks, Ed G
I got one and I broke one when I try to put that back in I push as hardest I could, do you know the easy way to install this mirror
I believe that the spring mechanism needs to be lubricated in order to work correctly. A teflon or silicone spray should be worked into the spring so that it flexes properly.
I just received the mirror from Ed (thanks!) and will be using the attached thread to hopefully remove mine and install the new one.
