Rear Window Operation
cobubas1
New Member
Kent, England
Hi, is there any way I can wind the rear windows up and down on my 1972 3.0cs without power - I.E - do it manually?
Regards
Colin
On my '69, once the door panel is off you can access the motor and turn it by hand. There is a white plastic gear on the shaft, it takes a lot of turns but you can raise and lower the window.
If you were really clever you could probably put a gear on a drill and turn it that way.
Many thanks for the reply, i have tried that but they do not appear to move. I read that there is a special tool that comes in the boot tool kit that may do it? Does anyone know about this or what it looks like please?
These are some of the last parts to remove for a full resto so I am keen to get them moving.:confused:Colin
It is called a "rack" and it looks like a nylon toothbrush. The NLA P/N 51 37 8 745 162. It came in both the Bavaria and the CS.
Freeing window motors
You don't say what year your car is. If it is a 73 or earlier with the metal can motor and separate gearbox, the window regulator mechanism can get jammed at the end of travel and may take some force to get it free. I've used pliers to get a better grip on the thumbwheel.
In my experience, the toolbox 'rack' part has not worked unless the thumbwheel was free to turn.
Regards
Colin
A finger (naked or wrapped) may substitute for the rack and it is generally easier to locate.
WARNING about using a finger though. Although this should be self evident, the nylon gear can bite.! So, if you value your digits, it is advisable that the key be in the off position or battery disconnected, to avoid inadvertently energizing the window motor and unleashing a 12v medieval pinching device.
To be clear, you are referring to the rear windows? If you are doing a restore - one presumes you have removed the rear panel (2 screws?) to access the mechanism. If so, you have two choices.
First try to overcome the so-called binding with your fingers or substitute tool. I suggest fingers since using pliers could damage the nylon gear. Don't overlook the possibility that the old rubber stop has become "glued" in place.
Second, remove the motor itself and make sure it is not the reason for the impeded movement.
Good luck!
Has anyone made a 3D printed version of the "rack", part # 5137 8 745 162, to wind the electric window mechanism?
I found that the manual wind gear moved the window exceedingly slowly. I think the first few turns really only took up the gear slack, and then it moved about 1- 2 mm per turn of the gear. So it was clear that THAT was going to take a while. Seems like a rather silly design where the entire system is unreliable enough to warrant having a manual backup, but the backup is not very effective... o_O
However, after I had moved the window a tiny bit, and gotten frustrated at the slow process. I tried the window switch again. Like magic the window went down... So clearly the windows were sort of stuck in place, and the motors could not generate enough torque to get them un-stuck. But, once they had been jogged a bit, they worked.
I also found that, even with the motors removed the entire mechanism was pretty stiff from congealed grease.
So, start by really cranking the manual gear until you see the window move a bit, and then try the switch. If that fails you can try removing the motor itself, which might free things up.
