Rear Window trim Etc
bavbob
Boston, Ma
In the image shown, does the outer rear window trim fit over a small lip of the aluminum inner door trim ? Also there is a rubber strip that runs along the bottom of this part, can someone confirm part number 51367740132? Also, anyone have one of these screws lying around for sale?
BTW: Image is copyrighted from Markos.
Yes, it overlaps. The U channel trim on length of the chrome is below sold by the meter:
Synthetic stripX09/196511/197554129734126$1.95
You can use a suitable chrome head coarse thread screw, it’s pretty small.
Worse case scenario,you could use a small plastic mollie. If you can give me a size of the hole I have different clips that hold some of the moldings.
Please let me know. I hope we can get together soon.
if you lift up the chrome part, you should find a hard rubber piece that screws on sideways with one flat head screw to the sheet metal which sits under the chrome piece. With the missing screw one fixes the chrome strip to the hard rubber piece. l
Those hard rubber blocks look like this.....
I found those plastic blocks so am all set.
Harry, agree but given the times and where I work, best you keep your distance from me for now.......................
