Rebuild early clutch cylinder
Stefan
Sweden
I have difficulties finding a source for rebuild kit to the early clutch slave cylinder.
Reading a lot of earlier threads regarding this issue the closest I get is the picture in member Buffarea's thread http://www.e9coupe.com/forum/showthread.php?t=6588&page=4 (page4)
showing a spare part box from Lucas Girling together with the slave.
Readable data on the box: Lucas Girling SP 3650 (RK 22073)
But, not 100% sure if this box contained parts for rebuilding the slave :-)
I sent Buffarea PM several months ago, but no response.
So if anyone of you guys knows anything more in this matter, It would be appreciated.
//Stefan
My bad!
Hi John!
Sorry about that I missed in the thread title to point out that I meant "slave" clutch cylinder. My bad!
I noticed that directly after posting it. Not possible to edit thread title afterwards :-)
Thanks anyway John. I've seen your posts about master clutch cylinder earlier because that could always be a "problem tomorrow"
My car had been sitting for nearly 30 years when I started to fix her up. All hydraulic cylinders were totally (I mean 100% totally) jammed.
The first one I started to renovate was the slave clutch cylinder.
Similar to all of us I was keen on getting started and perhaps I was to rough and used wrong liquid (that I know) to get the cylinder moving at all on the bench. So now 4 years later, it starting to leak a little. About one drop each week.
For every other hydraulic cylinders on my E9 I was using a smother method (only using hydraulic oil and similar) and done the homework before starting together with a lot of patience... :-)
