Removing under hood decal
BP1
CORONA del MAR, CA
h
How do I remove this old decal and adhesive without damaging the paint? Thanks...BOB
aearch
pleasant hill , ca
LACQUER THINNER TO BEGIN WITH THEN A PLASTIC SCRAPPER SHARPENED AS YOU GO
THEN POLISH IT OUT W/ MCQUIRES 103 AND ROTARY BUFFER
eriknetherlands
Netherlands, Eindhoven area
3m sells a rotary adhesive stripper wheel for these jobs. Now in this specific case, the label is placed over sound deadning, so not sure of the outcome / if it leaves the paint intact.
Erik
Gransin
Vasa, Finland
I've had good results with any kind of citrus based sticker/adhesive removers in spray cans, not harsh on the paint underneath, and dissolves the sticker glue in a while, you will need to apply several or even many doses and let it soak between, until the edges starts to come loose, and then put on more, repeat, repeat. Can't of course be sure it will work on such an old sticker, but with lots of patience I think it will work since no sticker that I have wanted removed is still in place.
However, I would be careful with getting the citrus on the edges of the sound deadening, would not be fun if that started coming loose.
