Replacement battery cable & additional relay location(s)
boonies
Cars aren't the problem, storage is...
US - Philadelphia suburbs
I have removed the battery cable as a part of the work I am doing to prepare for installation of new carburetors.
It seems that the OEM positive cable is NLA so was looking into making a cable and was shopping for parts when I came across an interesting site that allows the configuration of custom cables (link below), including auxiliary power cables if desired.
With the idea of custom battery cables in mind, what are your thoughts about auxiliary power cables (one or several), that could be run to relays or banks of relays or other needs?
I am planning for headlight and fog lamp relays at some point, and noted that some of you have added a relay for the starter motor as well.
