replacement bulb for Bosch rear fog light
autokunst
Milwaukee, WI
Hey there,
I'm looking for info to replace the lamp of the Bosch rear fog lamp I purchased from @enoz05
This is Enoz' photo:
I'd prefer LED or something less than the 45w lamp that was in there. I can't seem to find any info on this. Any help appreciated. Thank you!
Here are pics of the bulb that was in it (inop).
Additional information. Looks like the fixture expects a 35watt lamp as opposed to the dead 45w that was in it. Still haven't found info on the tungsten or LED bulb itself.
The base is slightly different in the rear fog (larger diameter and the pins are in a different location). But I think I can get these to work. WIll give it a try (and replace the regular brake light lamps as well). Heading to Michigan with the car and I want to be seen. Thanks!
Is it a standard size base? Go LED that I have recommended.
I don't think this bulb fit, the base is too small for the Bosch light
What's the diameter of the base?
Yes, that looks like a more direct fit. But I am going to try to finesse the smaller 1156 LED lamps to fit (I'll also use those in the traditional brake light sockets. Thanks for the input!
