Replacement Rear CV Joints
DGeoff
Canada
I have quite a bit of play in my rear driveshafts. I’m getting kind of a clunky/jerky movement as I go through the gears. I’m pretty confident I need to replace or at least rebuild the joints.
I’ve been to the Wallothnesch site and they have rebuild kits at about €200 per, and I need four! Does anyone in the group no an alternate source for full shaft or perhaps good used ones?
Thanks for any advice given.
Take car for a drive. When going down a hill place in neutral and keep clutch depressed.
If issue goes away, then it's not the CV's it's in your box/drive train. CV = constant velocity, sounds like your issue is linked to gear changes.
God, I sound like @sfdon Don :D
Thanks everyone. I really appreciate the feedback
My issue isn't really a noise. Its more a "feeling". Kind of like there's slack on the drivetrain which takes up as you decelerate / accelerate. I was told by a local mechanic it was the CV joints.
Don't know if its related or not but, at stand still in neutral clutch out I get a soft "shick-a-shick-a-shick" noise which goes away when clutch is depressed.
Now I'm a bit diagnosis confused. :(
