T
tripower
Guest
Does anyone make a pre-fab or bolt in Roll Cage for the E-9?
shanon said:Well..............I haven't been able to find one and my brothers and I have looked. So, my brother had a custom CS 4pt bolt-in cage w/ Martini bar built and it has seen 2-3 seasons of VERY active use since. It has been accepted by VARA, HMSA, HSR-West and SCCA Vintage.
We are going to take his out and make a copy for my CS this spring sometime and if there is serious interest, we have considered making a batch.
If interested let me know here and we can possibly work something out.
Cages will be built in Monterey, CA.
-shanon
'70 2800CS
Yes the following do or did
Sparco
Roll Centre
Safety Devices
Other sources include Jaymic in Norfolk UK and Walloth & Nesch in Germany
Malc
Jamic did list them a few years ago, but I don't know if they still do I imagine that they will. Here are the part numbers you will be intrested in.
Part no
CSBD 6590 Roll cage rear removable diagonal LHD
CSBD 6600 Roll cage rear fixed diagonal LHD
CSBD 6520 Roll cage front
CSBD 6530 Roll cage front door bar 1 side
CSBD 6560 Roll cage front (road use only)
CSBD 6570 Roll cage rear (road use only)
Of course these will appear to be quite expensive to you lads over the water due to the currency conversion rate, having said that it may be cheaper than getting one custom made.
I fabricated my own cage it's a 10 point affair so it'll stiffen the car up significantly but I wouldn't fancy doing one again.
