I have had luck with an Eastwood fender roller slow and steady with another helper with a heat gun holding the paint at about 125 degrees. Different paint and different results for sure. If you can get away without going whole hog and doubling the sheet metal on itself that would be good. You shouldn't need to. Actually, just zero in on the area that would be prone to rubbing. Good luck!
