Roof drains Sunroof seal replacement?
jranmann
Banned
Southern California
Would someone please explain the best way to clear the roof drains (where they are located on a Sunroof Coups 72CS )and also direct me to the procedure to replace the felt seals on the same roof?
Cheers!
Ran
Thanks Andre for that link I do recall seeing it once as it's been around awhile.
Now I just need to know the pathway (drainage) to help me locate the openings in the roof panel and pillars.
Cheers!
Ran
Here are some pictures from my 72 coupe. Picture 12361 shows the rear drainage tube. It goes from the corner of the sunroof cage (where the sunroof slides into when open) to inside the rear pillar. It's the larger tube. The two small aluminum tubes is where the sunroof cables travel. Picture 12366 shows the path for the front. It also goes into the pillar. There are 4 drainage, one in each corner. To access them you will most likely need to remove the roof lining. You may be able to access the rear ones by lowering the roof lining from the rear to the first tension bar holding the lining. The front ones may be accessed by rmoving the section where the sun visors are. Hope this helps.
