Rubber Plugs
Recently the subject of rubber plugs came up and I was looking for the two in the spare tire well. I think they are the same as the two that mount in front of the hood latches. Just for fun I went to the dealer and ordered two. Attached is a pic with part number and the original plug on the right. Looks to be a good fit, they are for the 35mm opening, the inside will look a bit different but it is a good solution for an NLA plug.
I have an even more obscure plug need. My diving board bumpers have two 1" diameter holes in the rubber rub strip on the front, no doubt for mounting a front plate. The PO installed an undermounted plate, so I'd like to fill the holes. Sorry to hijack your post, but I'm open to suggestions...
Chris, same, here.
I also ordered the plugs at the dealer, and got hthe same. However I find them a bit flimsy, plastic instead of rubber, and I wasn't convinced that they belong on an (my) E9.
If anyone has the originals for sale, then i'm interested. I'm also looking for the one under the rear seat.
You might look through here.
