Once you mechanically remove as much rust as possible I recommend you use a chemical rust conversion treatment before any primer. There are very good treatmentssuch as PPG DX 520 (replaces by SC520) or POR -15 metal prep. These etch microscopic rust and leave a zinc-phosphate coating to prevent future rust formation. I’ll bet if you do this and do a good job top coating then your rust issues won’t come back.
If there is rust thru, it’s an entirely different matter and you should cut out and replace metal.
Good luck
Good luck
