My 3.0CS has a non factory York a/c compressor with a custom made bracket rather than an OEM one. The compressor is leaking so I think it’s time to switch to a Sanden. The Sanden brackets that I’ve seen available appear to be adapters that retain the existing OEM York bracket. Except I need to start again from scratch as my York bracket is welded fixed with no pivot as you would normally expect for adjusting belt tension.
What’s the best strategy to mount a Sanden if I’m not re-using the existing custom York brackets?
