I am getting no ground to one window motor. I am using the diagram in https://www.shiftbmw.com/wp-content/uploads/2020/06/BMW-E9-3.0-3.3-cs-csi-owners-manual.pdf which is not quite legible...
A few questions:
1) Does the ground make it through the door wire harness or is it grounded locally inside the door?
2) I assume terminal connector 111 is inside the door, but where is plug board 112?
3) How is the wire harness routed to the window switches? Under the carpet or behind the side trim around the hood latch handle?
The motor works in both directions when an external ground is brought to motor in the door.
A few questions:
