Malc
DustyM said:If fluid was squirting out of the bleed screw on the clutch slave cylinder when you bled the fluid through then the hydraulics are probably working.
Another possibility is that the clutch friction plate has rusted to the flywheel so even though you are depressing the clutch it is not disengaging.
To free it off try starting the car in gear (fourth?) with your foot on the clutch - Make sure there is plenty of clear space in front of you!!!
Let it warm up first though!
foot on clutch and brakes helps!
Agree with Dusty M lots of space required!
