Seat repair
aearch
pleasant hill , ca
Seat release repair
So if your seat release wont work weel
you can pull the cross rod to each side lever
ans its held with a very small circ clip
its made of pot medal and you can use a
paper clip and slide it d and the lever notch
its fits perfect and will tighten so both
work in perfect conjunction.
after furthur adjustment it seems a needle is needed to
make them fully tight
Pics
So its hard to see but the rod has four sides
and the lever has eight faces as in 6 for a socket
so you slide the needle in the open 4 "slots"
then put the clip back on
they get really tight
i set the needle with a small set of vice grips
It is pretty clear, I was even able to apply google translate to it:
所以,如果你的座位版本将无法正常工作
你可以拉动横杆,以每边杆
ANS其曾与一个非常小保监会夹
其制作锅奖章,你可以使用
回形针和滑动D和杠杆缺口
其配合完善和将收紧所以两者
在完美的配合工作。
后进一步调整它似乎是一个针是需要
让他们充分紧
I think I have a lever on only one side per seat. I will check when I am home.
