Self tapping nuts in door.
Jasper
Copenhagen
Another day, another assembly headache. I’m assembling the doors and the screws for the armrest don’t fit the welded on nuts in the door anymore.
How do I advance from here? I know the E3 used plastic/nylon nuts that fit the square hole. Do I remove the welded nuts and substitute with the red ones? Or another kind? Or do I jimmy the nuts somehow so they can grab the screw again?
Are there actual nuts? I thought there are threads intrinsic to the door sheet metal. You can use rivet nuts. You can rig up a system to install them without buying a rivet gun.
What dose means dose not fit anymore?
Is the screw too big or too small?
To small, tap with a hammer on the welded nut from backside to get the hole smaller.
To big, wrong screw picked.
Brei
The holes - some of them - are bigger than the correct screws. And worn to a degree that flattening isn’t really an option anymore. Perhaps someone before me replaced them with the E3 plastic nuts or something completely different.
Or rivit nuts. They’ll work.
I had the same dilemma.
In my case, the original screws didn't catch the sheet metal thread thingy welded into the door.
I replaced them all with M5 and M6 weldnuts
Erik, that has to be the gold standard. Well done. I ended up squashing the threads with a 4mm bolt, nut and a handful of odd washers. It worked well on the three threads that couldn’t hold a screw. Crisis averted for now. Next time they act up, the threaded plates will be removed and replaced with red clips or caged nuts.
