shift knob adaptor for 5spd conversions
FjordTempo
Costa Mesa, CA
Fellow 5 speed converters
I would like to use my old screw-on shift knob, but have a newer push-on shifter with my 5 speed trans. Has anyone bought one of the converter/adaptors? A little extra length is not a problem, in fact, I could use an extra inch or so ;)
Or, if there is another option I'm not thinking of, please share.
thank you,
Matt
rsporsche
Atlanta, GA
you just had to go there ... the initial thought was to take the other approach. as in ... hmmm, not needed here ...
Sven
Seattle
Matt - I am wondering if you could have a machine shop thread the end of the shifter arm. It has a slot at the top but there may be enough material left on the sides to thread?
FjordTempo
Costa Mesa, CA
still baffled by shift knob options - help
With my 5 speed conversion, I have a push on shifter fitment for shift knobs, but really want to use a period correct shift knob, most of which are threaded.
Those of you who have done the 5 speed conversion, are you using a newer push-on shift knob, or does someone make a converter that allows us to use a screw-on knob with a push-on shifter?
Thanks for any help you can give. I've searched the forum and must be missing something obvious.
thank you
Matt
For my current 5 speed install project I am going to use the lower half of a 320i lever with the upper half of my stock 4 speed lever with threads. 320i also provides a slightly shorter throw.
