We are about ready to perform rocker panel repair on a 2800CS. Plan is to essentially strip the car, interior out, motor trans out, suspension out, etc. etc.
Body shell to be put on a temporary dolly. I've seen several restoration threads showing several versions of temporary internal bracing when cutting out the rockers.
For those of you who did use bracing, can you provide some more detailed photos, where are the attachment points, dimensions etc. Links to relevant threads also aprreciated.
It looks like in the threads I've reviewed, the doors have to come off.
We have purchased the outer rockers from W&N as well as the front, back, left, and right lower quarter and fender repair pieces. As well as the A and B pillar internal supports.
Using an endoscope, the intermediate rocker panels appear to be ok, except for some areas of concern, so no complete replacement is expected. Car spent most of its life in CA.
With the car stripped how necessary is the bracing and if needed, really how stout?
I do not want to reinvent the wheel here, or go overboard with tons of bracing, so appreciate any info.
Thanks very much!
jjs2800cs
Thanks very much!
jjs2800cs
