Slightly OT: Need help shimming '02 open diff side gears
sreams
Sacramento, CA
I'm rebuilding an open diff for my '72 2002 and have run into an issue. One of the side gears has a bit too much play and needs to be shimmed differently. The shims needed are #07 here:
http://www.realoem.com/bmw/enUS/showparts?id=ST12-USA-01-1972-114-BMW-2002&diagId=33_0867
I might also need #06 as well, although the two diffs I have only appear to have two shims per side gear... no "diaphragm spring" (unless #06 looks just like a shim?)
Trouble is, these are NLA from BMW and I'm not sure how to proceed. Does anyone have these lying about? I'd like to get a hold of all the ones that are thicker than 1.3mm. Thanks!
-Scott
I had my diff rebuilt at a shop that specialized in doing large equipment trans and diffs. When I went to replace the front seal on my trans, I found a lot of play between the housing and bearing. I went back to the shop that did my diff and he had tons of shims and gave me a bunch. Point is a trans or "gear" shop should be able to help you out with your search
