sreams
I'm rebuilding an open diff for my '72 2002 and have run into an issue. One of the side gears has a bit too much play and needs to be shimmed differently. The shims needed are #07 here:
http://www.realoem.com/bmw/enUS/showparts?id=ST12-USA-01-1972-114-BMW-2002&diagId=33_0867
I might also need #06 as well, although the two diffs I have only appear to have two shims per side gear... no "diaphragm spring" (unless #06 looks just like a shim?)
Trouble is, these are NLA from BMW and I'm not sure how to proceed. Does anyone have these lying about? I'd like to get a hold of all the ones that are thicker than 1.3mm. Thanks!
-Scott
-Scott
