Hey folks -
I've been playing catch-up in many things recently and the Coupe is one of them.
Some of you may recall I purchased my car last fall from Tony (Velocewest). So far, the car has been wonderful. Not perfect but - More than I could have hoped for.
I have some things I wish to pass along that I've found out since I have had the car.
Again - If anyone wants to take me up on the gasket material for the front turn lens' - just PM me.
Thanks-
- Front Turn Signals
The car came with a busted lens for one of the front turn signals. Tony was 'looking at e-bay' for a replacement thinking the European lens' the car had were not available here -
A little sleuthing on realoem.com and (with part number in hand) a call to my dealer - and a new lens. ~$115 if I recall correctly. I talked them down from 'list' - and much more than the CCA membership would have gotten me. - Speaking of turn signals.... Lens Gasket-
That same turn signal's installation was missing the gasket between the housing and the lens. This was letting water into the reflector area when I washed the car. But more importantly - it was causing stress on the lens as the lens didn't want to sit into the housing (without the gasket to take some space) as far as the two screws would try to pull it in....
Short of ordering the entire assembly (for a premium $$) - I thought ..... "Why not use a large diameter O-ring?"
I did some math and found a size that works... I got a set of them from Grainger but found them a 'little' too small (They'd work - but I wanted better)
So - I ordered a bit bigger.... ok... Too big and I had to cut them down but .... The diameter of the rubber is perfect and cushions the lens nicely.
Now for my offer - I had to get a pack of 10. I have the 'extra' parts that are left over. If anyone wants one or two - PM me and let me know. First come - first served for anyone that wants my extra's. I also have the ones that are shorter - I'd be happy to send those out if I run out of the longer ones.
For those that would like to know the AS #.... AS568A-253 is just a shade long. AS568A-251 is 'ok'. I should have tried the AS568A-252 to see how it fits. - Ballast Resistor
I recently installed a new distributor. In messing around with the electrical connections when it was installed - I found the ceramic housing of my ballast resistor had cracked in half. Finding a replacement proved to be interesting.
Even with the Bosh P/N & resistance value..... I had a hard time finding an equivalent short of spending $70.
I came across a Mercedes series of Bosch and Beru ballasts.
F3020-11627 is the WorldPac P/N for my 0.9 ohm ballast. Less than $30 from Importec.com - Alpina 16" Wheels (Reproductions)
Some of you may remember this http://www.e9coupe.com/forum/showthread.php?t=4257 thread.
Turned out the front tires clipped the fenders - just a shade. I had to get the fenders rolled. Not a huge deal - just one of those things. Thought folks would want to know.
Thanks-
