bimmerboy73
went to start the car today after lunch and it wouldnt turn over. Had it out for a nice run during lunch without incident. I have noticed a slight fade in ignition strength at startup over the last few days but nothing that caused alarm. Just something i noticed. Anyway, checked all the ignition wires, checked fuel pressure, changed plugs, checked battery terminals, starter connection, dizzy / coil connection (msd coil... starting to wonder about it ) and all check out ok. So... one thought is that it could be the ignition kill attached to the alarm system installed by the PO (Alpine 8027 with keyless entry). Only considered it as a possibility because the battery in the remote conked out on me recently and i had become concerned that if the system sets itself silently and automatically ( it would be silent in any case as the horn connection was severed by the PO) and i coulnt disarm prior to entry that the system might cut the ignition. However, the engine does try to turn over, it just wont catch. Which makes me think that the alarm might not be the culprit ( i seem to remember the ignition kill in a previous car of mine would just yield a click ... click click sound if it was enabled). So now i'm thinking that maybe the points are crap. Hadn't gotten around to them yet as i was trying to track down a Mallory elct. dizzy to install or a pertronics system. I'm new to the point system so am not familia with the warning signs or symptoms of failure. Is there a visual indication at all? how can i check wear? Only other clue i could add is that i had the car at cruising speed today (~80mph) for the first time since i've owned it. No unsual sounds, temp was normal the entire time... everything seemed perfect...
So... its 930 pm and my car is stranded at my job... dont think i'll be able to sleep tonight. Would love to at least get it home so that i can tuck it away in the garage.
Your help is greatly appreciated.
Oh... carbs are newly installed and were just rebuilt.
Did i mention that there a $11 reward to anyone that can help me get it started...
