In reading through the recent posts I feel that this is insignificant but has anyone experienced a truly defective spark plug? I believe I have in that it works intermittently; My car had a miss in it so I started at the lowest common denominator, the Pertronix, but that seemed all set up correctly so I went to the timing (this is after I changed new carb base plates and ruled out vacuum leaks). When I put the inductive clip on #1 wire there was no strobe, I checked all the other wires and the strobe was flashing like an old disco. I checked the wire-through the cap- changed out the wire-and the cap (with the old one) and still no spark/strobe. I pulled the plug and attached it to the wire and got a spark from the tip of the plug, but when I put it back in I could get no strobe. In minor confused desperation I switched with the plug next to it and the #1 immediately started flashing like mad but the one I switched it with was dead. The plugs were brand new and were Bosch (Chinese?) Platinum Plus. Is there a better plug for these cars? Or did I miss something in my diagnosis?
Any help/comments appreciated,
