decoupe
(deceased)
The cable sleeve has separated (pulled out) of the metal crimped housing at the transmission speedo drive. There are three cables listed for the e12 donor Getrag 265 though ...399 looks out of production.
I would rather not pull the existing out to measure it - if someone can recall which cable is the best fit - as the unit still works if I push the sleeve into the housing.
1981 e12 5spd
02 SPEEDO CABLE LOWER PART L=500MM 1 09/1979 62121359399
02 SPEEDO CABLE LOWER PART L=690MM 1 09/1979 62121359397
02 SPEEDO CABLE LOWER PART L=730MM 1 09/1979 62121359333
1981 e12 5spd
