An update on the sticking starter is in order, along with some questions.
1. Do the easy things first... what came to me is that it ...might... be that the ignition switch was sticking in the "start" position.I spent some quality time with the electrical diagram from the Blue books, this was DeQuincey's suggestion, thanks... and found that the red wire to the switch is always hot from B+. In the "Start" position it powers the black wire which leads to the solenoid. There is a connector inline with that black wire under the dash, so I disconnected that, plugged in my test light and had my able assistant turn the key to "start". The light came on, there was no flickering, and went off as soon as the key was released to the "run" position. This gave me no joy, because it meant the switch was good and the problem was under the hood, where I'd hoped not to have to go.
2. Today I removed the rear carb and manifold together. I'd rather replace a transmission. But I did discover there is a lot of white corrosion cr*p on the manifold immediately below the water choke, though the two little choke hoses appeared to be intact (they will be replaced). Not to worry there are other hoses down there too. They will also be replaced.
3. I bench tested the starter with the battery and a momentary switch. The motor turned and to solenoid shoved the pinion gear in and out though not as snappily as I expected and on the second or third try the pinion gear would not retract. I removed the solenoid from the starter and it seems to be solenoiding in and out well, leaving the problem to the starter shaft or bendix (I think this is the correct term for the one way ratchet system for the pinion gear).
4. Removed the two long screws on the end of the starter. I tried to separate the starter motor from the cast iron housing enclosing the pinion gear, but could only separate them parts about half an inch. Quite a bit of black semi-powdery stuff came out, validating that it was due for cleaning.
QUESTION TIME... thanks for reading this far!
Q1. What am I missing that prevents disassembling the starter from the pinion gear assembly and casting?
Q2. Is the solenoid the only thing that retracts the pinion gear from the ring gear? It seems my pinion assembly (somewhat cleaned, and now lubricated a bit) will almost slide back and forth by gravity alone while the solenoid is removed. Is there a return spring hidden in the casting? If there's supposed to be a return spring it's not working and I'm in for a new/rebuilt starter.
Q3. Is there a chemical agent to remove scaly/bubbly corrosion from the manifold? I can use a degreaser then shop for some media blasting, but is there a better way to remove the white scaly stuff that threatens to eat through the water hose nipples below the manifold?
