Honolulu
The time spent means nothing to me as I am currently unemployed and this is a great excuse to keep from doing something useful. Does any of that ring a bell with any other coupe owner?
This afternoon I got the starter back together with the solenoid and hooked up the battery cables and a momentary (remote starter) switch as pictured in one early post. The starter spins like a champ and the pinion gear extends and retracts just fine. It seems the whole problem was probably that there was too much crud in the bendix for proper pinion retraction. Another fine data point for the joys of coupe ownership and old cars generally!
The apparent answer to my most recent post seems to be that without the solenoid, the pinion gear should in fact "fall" back and forth by gravity alone. Tomorrow I will reassemble, synch carbs, and if all goes well, sally forth for a drive. We've had great Hawaiian weather: sunny and upper 70s for a hour followed by quite a drizzle for as long as it takes to down half a liter of homebrew, then clearing in half an hour to sunny again. And again. Literally, if you don't like the weather, wait five minutes.
I've been through the carbs and don't want to go there again. The manifolds are another story, and no one has posted useful dope about cleaning them or the corrosion on the rear manifold. As it happens, I know a lady who operates an aircraft servicing operation and she has quarts of both Alumaprep 33 and Alodine in stock. I have some zinc chromate primer left over from a friend's nautical adventures, now all I need is some two part epoxy paint that looks like aluminum... which I think I may have. Apparently I like hazardous chemicals and clean parts rather than unfinished original casting.
