OK, so its my turn to replace my original starter. I have a Weber carbed '72 CS.
Have read many tales of woe that popped up with a "search" here, and have accepted that this job ranks high on the : "never want to do again" list. I take solace in have lived through a heater core replacement in my son's E36-real bonding moments over several days there! So I believe I have seen bottom and feel like I can move forward.
I have noted that the Bosch SR441X is a popular replacement for the original unit. I have located my slim Heyco 17mm wrench in the trunk lid toolkit, have procured expendable 17 mm sockets to cut down, other sacrificial 17mm wrenches to bend, grind, throw..and am about to start in. However, there have been many references to having to remove back intake manifold and carb. Really would like to avoid this. Please...someone...tell me that they have completed this mission without having to resort to removing that back manifold.
Plus, any particular electrical connections that are different when trying to connect the 441x? Wish it was all as easy as the common Autobooks/Haynes/Blue Book entries that simply state, disconnect negative cable from battery, detach wires from solenoid , unbolt starter and lift away! Any tips/recollections/notes of encouragement welcome. Thanks, Mike
