Steering box adjustment
bavbob
Boston, Ma
Know how to do it, just cannot get to the top for adjustment. Best approach? Do you remove the brake booster and come from above or is there a way from below?
Use your screwdriver from the side into the slot.
Don't over tighten the adjustment screw it can hamper steering wheel return when you make a turn.
I fabricated a screwdriver but I cannot get the screw free from the nut so both turn...thus cannot tighten the screw more than it is. I sprayed BP blaster in there and no effect. I have done this with both my e24's...where the top of the box is real easy access.
thin vice grips
i had this same prob, and was able to break free by using a pair of thin vice grips to grab the shaft, and box wrench on nut - buggers up the shaft a little, but not bad.
So- when's the last time you bled your brakes? Maybe it's time.
I would try a Heyco thin 17mm and your homemade screwdriver first.
DOOOOO. I keep forgetting the toolkit that came with the car. I assume the 17mm is in there. That is the problem I have been having, wrench will fit and screwdriver fill fit but not both.
