Stock E9/E3 wheel treatment
This has nothing to do with wheels, but I was cruising for a spot to take a picture of the new wheels and couldn't pass this one up...
I mounted tires yesterday and swapped out steel wheels with the aluminum E9/optional E3 wheels.
The steel wheels/hubcaps/trim rings are still my favorite but I like the stock aluminum wheels a lot and it will be nice to be able to change up the look every now and then. I still want to see if we can make the center bore cap and exposed lug nuts work. That will give me a 3rd look.
Dick, i love it both ways. the stock trims + covers just look great on the Bav ... but the coupe wheels also look great. i have to say what i like about the trims + covers is the sparkle of the chrome.
Do you have different kinds of tires mounted on each set?
Essentially the same tires on each set. 205 70 14 touring tires. The ones on the E9 wheels are Touring VP Plus from Discount Tire. 50,000 warranty, 540 tread wear, A traction, A temperature, speed rated to 118 mph. Hardly a performance tire. The ones on the steel wheels are similar but Toyos from Les Schwab.
I finally got around to testing this and yes with the tabs bent it should work. I’d also wrap some tape around the perimeter of the tabs.
I also tried a turbine center cap (my preference for Alpina wheels on non-Alpina cars) and it’s pretty loose and too tall. I think this is the winner and still looks reasonably period correct. Would be even better with some white letter Radial T/As.
Very impressive dual-threat...to be clear, the small cap is 36131117649, correct? I think that the price of old alloys just went up...
It's this cap, Dave....
They are expensive new, but plentiful used. I got mine off eBay. $30 for all 4. They cleaned up.
Thanks again for the idea!
