I think you need to determine 'what you will be doing' with the car., Sporty or Plush? The set-up described works great for a street car to be driven enthusiactically. That's the setup my brother and I used before we ventured to HPDEs (track days). The set-up will present it's short comings on the track, a bit soft, rolls too much in the corners.
Suggest bigger sway bars to minimize the roll of our 'Das Boots'. If your doing a complete resto, change to Poly bushings while your in there.......
.....itsa  Pandora's box though. But if you'd like see more mod ideas, check out Ireland Engineering for some bits......the coil-overs are awesome.  :twisted:
HTH
-shanon
