Tacho wiring with coil on plug ignition
The ECU should have a Tachometer (square wave) output that can drive the Tachometer. However, you may have to convert the output to a pulse signal using a Tachometer output convertor such as the Haltech HT-038006
Or…if the ignition coil is still there, them you can simply take the “negative” side of the coil and feed the tachometer input signal.
